1 - 8 of 8 Posts
I am helping to repair a potato picker that was made in Switzerland.
The gear box which runs a shaker to sift the potatoes out of the ground is on it's last leg's.
Doing a Google search using the manufacture's name turn's up NOTHING.
My question is, is there a USA Google search as opposed to a European search?
Jim
Helps to translate what you want into the language you want the answer from.
Kartoffelpflücker/Kartoffelmaschine is potatoe picker or machine in german....swiss is about the same, austrian etc. and hold on I'll get you the swiss link if I can.
Zim
Señor Member
What's the brand of the potato picker?
Just Sayin Crew V.P.
This is what I love about the bullet is all the diverse fields people are involved and the knowledge of what they do. Much different than the usual yoyo's I deal with here in my area. It seems like I have to do the brain work for the supposed professionals in the construction industry by me. Just went through this the other day with an HVAC company where the owner is a mechanical engineer where I had to explain to him the Trane units he was going to use did not work for the application. He missed that the economizer were set up for a vertical feed versus a horizontal feed. Would of been I train wreck if I did not dive into the specs because it was for all 13 units.
KEVIN CAPS LOCK
I KNEW THIS SWEDISH POTATO PICKER ONCE.....
1 - 8 of 8 Posts
