1 - 20 of 20 Posts
:(:confused:looking to find a tuner that has a clue about 05 and up mustangs.i have a 05 with a procharger/methenol injected this shitcan wont run longer than 20 mins w/out putting the check engine light on.
Definitely call Mike Dezotel. Dez Racing, He's gotta have a car with that same set-up go through his shop, at least once a week.
If you could get a hold Of Eric, I'd say Laferriere Racing hands down. He is the man when it comes to Procharger setups.
I'd try Eric LaFerriere I believe he's outside Boston
I believe he is actually in RI but it is not to far. Dez is in seekonk right across from the speedway.
He's in Johnston, RI, but is almost impossible to get a hold of nowadays. Sure Dez can handle it too, but Eric is without a doubt the most talented Ford guy in New England. Just remember no tuner can fix a bad combo, they can only make the best out of a bad situation, so hopefully it is just a tuning issue.
On the roller...
What's it throwing the MIL for? Do you know? I'm obviously not in the Boston area, but I do have a network of friends in the biz... Just wouldn't mind having a little bit more info before referring you to someone. Why the meth?
1 - 20 of 20 Posts
