1 - 2 of 2 Posts
have a 615 bbc sonnys heads 572 on the intake 381 on the [email protected] 900/ 11 to 1 compresion its a blower motor ,but im going to skip blower for a couple of years and run 2 stages will this cam work heres the specs//877in 877 exh //279 285 at 50 116 ls // is this a good spray cam or should i change it ,,the car needs to go 750s or better 2700lbs race weight big tire 4 link 1079est hp and how much spray should i hit this with
I guess I'll have to get the troops going as usual !!! ;)
My thoughts are to go for it.... The cam has decent lift, a little more exhaust event, and a good L/S.
The car is fairly light, and is making good HP now it sounds like ?? I'm guessing it should take about 15-1600 HP to get you @ the 7.50 goal your looking for. That with two properly set up and tuned systems should get the job done... Good luck and feel free to give a shout if I can help you out with your set up... Thanks, Steve
1 - 2 of 2 Posts
