I would taper the barrel to .9 to1.0 at the muzzle- maybe flute it too. Thick barrels that long are very heavy- and very front heavy. They have terrible balance.
Put a muzzle brake on it- but make sure it is easily removable with a cap to protect the threads when not in use. I like the "muscle" brake.
Get at least a 14 in. LOP- with an adjustable cheek piece. 14.5 LOP would not be too long.
TIGHT chamber- not a turn neck- but not a loose factory one either. Something that allows .003 or so neck expansion and only .003 or so shoulder blow out. Tight chambers are more accurate and the brass lasts a LOT longer. Less frequent trimming, annealing, etc.
Throat it for Berger 195 bullets. The gunsmith should know how to set everything up for you have minimum free-bore, loaded round will still fit in the magazine, etc.
I would talk to a couple reamer makers and tell them what you want to do. No doubt there are reamers available.
If you get a custom action have them put a 20MOA rail integral to the action.
