Well I am gonna change to PRO EFI this winter and I was wondering which way to go for Throttle body set ups. I currently have 4500 dominator blow thru carb on it with the ev hat, would it work if I did a 4500 throttle body and use the existing piping or is it worth the change over to a elbow and single blade throttle body?
only thing ive seen is the TB for the carb flange cost more money then a single blade. but then you need to factor money in for the elbow so i think it becomes a wash. the main reason for the single with the elbow is hood clearance. you dont have the problem so i would just run a 4500 style 4 bore TB.
car looks awesome btw, what company makes the hood
The 4 barrel style throttle body's are generally much shorter than a carb so you'll have to get a spacer made for your hat to fit right with no mods.
