301 - 320 of 344 Posts
Discussion Starter #301
Is that a 4wd or ZR2 rear? Be careful as the tubes neck from 3 inch at the case to 2.5 inch and are a known weak point. I highly recommend a second gen housing or at minimum a LPW type cover with struts to the tube ends.
It's a 4x4. ZR2 are too wide.
Sent from my GM1915 using Tapatalk
Discussion Starter #305
I made my list longer and shorter today.
I'm down to:
1. Install driveline (when it's done)
2. Add gear oil
3. Change front springs
4. Bleed brakes
Then I added fluid to bleed brakes and found a broken hard line on the axle so:
4. Rebuild hard lines
5. Bleed brakes
draggin' ass
Did you upgrade joint size? I plan to go 1350 on my Monte when I do my 6 speed swap to compliment the 8.5 i have out back. I did the same on my Blazer and have no complaints with the 4 inch aluminum shaft in it.
Discussion Starter #308
Today I got the driveline in and the brakes done.
Ran into a snag with the driver axle, someone must've beat it with a hammer the center hub is mushroomed and so the wheel won't go on that side.
Not upgrading those yet. Just the stocks.
Discussion Starter #309
And we are back on the ground.
Now I just have to finish my front spring change.
Almost ready for Turbo Thunder at Woodburn this weekend.
Discussion Starter #313
Got the truck working pretty good. Ran my best on wastegate mph ever, good 60ft on low rpm. Gonna leave it here for the brackets. I'm sure I'll lose first round and then I can go to the TnT lanes and turn up.
