Hiya, have a 2003 bravada(trailblazer/envoy etc) had a leaking power steeing line from a pinhole. Worked fine other than leak. I repaired the line and now no power steering? I have fluid pumping just not at pressure. What could I have done wrong? There are no kinks in the line or debris that I can tell. Could a pressure valve or similar in the pump be stuck or not working now? A little stumped here as all I did was repair the line and now no pressure. Thanks in advance!!
