Yes it is inside the cover.
Now she just told me that sometimes the secruity light will flash a few times the day before it acts up. Shit im thinking maybe a bad key. Anyone ever run into a problem like this.
Where is it located. Will it have to be programmedvery rarely, I ever had to replace the N.S.S switch.
99.99% of the time is the passlock sensor / anti-theft sensor.
FYI...it is not the key...
replace the passlock sensor / anti-theft sensor, your problem will go away....trust me on that....I've done that passlock thingy almost every week.
I agree 100%..Seen it a gazillion times.very rarely, I ever had to replace the N.S.S switch.
The large part of the key the part you hold is black. with a BowtieIIRC, it is in the ignition lock cylinder, as long as the key doesn't have a black resister in it
programming is easy, key on for 10 minutes, then off, and repeat 2 more times
They're located inside the igntion lock cylinder.Where is it located. Will it have to be programmed
