I've got an 09 Silverado that I keep having the same issue with. After driving for about 15-20 minutes with the heat on, it will start blowing only cold air. I can sometimes get the heat to come back if I turn the climate knob back and forth but usually once it starts blowing cold air that's it there is no more heat until I shut the truck off and start it again. As soon as the problem develops I take it right it to get it fixed but it just doesn't last.
The first time this happened was about a month after getting the truck in 09 and was fine for the rest of the winter. Then this fall/winter as of today it has happened 3 more times. I have taken it to the dealer each time and the first two times they replace an actuator and the last time they replaced the climate control panel. I think it is something electrical related but not sure.
I was just wondering if any of you guys have heard of this issue or if there was any kind of bulletin on it. This is starting to piss me off and never fails that it quits when it's freezing outside (it was 6* this morning, it was a cold ride to work that's for sure) Thanks in advance for any help.
