I have a 97 Conversion van 4.3.Yesterday I was driving and when I exit the Expway ,came to a stop and was setting there when all of a sudden the starter engaged.I turned motor off once realizing.Turned key back on and started .... started engaged again pulled into gas station and kept turning van off and on trying to get it to stop.No luck as soon as key is in on position Van starts no need to turn key to start position.Now if I turn key to Acc position then on Van wont start in on position but as soon as you do start the van the starter reengages a few seconds later.I ended up Jacking van up , and positive wire and start wire are not touching to cause I short that I can see I started van then pulled the start wire out of connector to get it home... any ideas on what causes this....I am assuming it has to be in ignition switch but not positive.
