1 - 17 of 17 Posts
hey guys, prett new here to the forum and looking at a GM sportsman block P/N 12480157 for a very reasonable price. it's brand new, never been machined and am wondering if it will hold up to the power i'm hoping to make. its a 350 main w/ nodular iron 4 bolt splayed caps and 400 bore size. i have a rolled set of 18 degree brodix pontiac heads that flow right around 350 cfm's at .700" and am looking at 250-300hp worth of nitrous. looking to make 675hp on motor (w/ E85) and the extra 250-300 on the gun. think i have a shot at keeping it together? thanks for you're help.
DamCoonass
I would change the caps, pour it & run the snot out of it.
yea man, was definitely considering a fill. i guess to change the caps i could probably get them from gm and have it line bored.
if you are going to the expense of changing caps and fill a brand new block... just get a dart block. I think you will save money in the long run.
X3
Those nodular caps willl take the Beating all day long @ that power level...........
make sure it's stud'ed..... and the rotator balanced right, and let it eat................
FWIW, you should be able to make 725++ with those heads on motor alone.......
X2
Before they had all the Billet caped blocks, the sportrman block was the choice block. I would run it!
Discussion Starter #10
thnx for your help guys, i can get it for around $1400 so it's way cheaper than a lil m or motown. and as far as the heads for 725hp, that would be nice! keeping compression to around 12:1 so i figure 675 is a good conservative number with a single 4150 carb, but definitely agree that 725 is feasible. have some cash to blow on this thing, but trying to stay on somewhat of a budget.
Dart SHP is 1446$ new? Whites performance and machine has them all machined and ready to assemble. 423-288-3881ph.
Discussion Starter #12
yes, i have seen very good deals on the SHP blocks, but i'm under the impression that it's going to be at a marginal strength level making this kind of power? dart rates them for in the neighborhood of 700hp, which i should be over by 2-300hp. idk, maybe i'm just being a bit conservative, as i hear stories of these guys making 800+ on 4 bolt truck blocks, but then again maybe they're just stories after all?
:confused:
Dart is very conservative on thier ratings. I'm sure there is people on here that make considerably more than 700, with thier SHP's.
I think either one will work just fine. The Bowtie "might" have a better Bulkhead on their block. Maybe Carl or someone else will chime in. But either way, they both will work fine!
Seeing that block is 1184 casting with the thick bulk heads its not a bad piece.
Dart rates there Sportsman block around 1200 horse it uses a 2 bolt front cap and 2 bolt rear cap with 1/2 hardware.
The Bowtie Sportsman block use 4 bolt caps from front to rear.
I would stud the mains down the center and run it as its better then the SHP block and I feel its as good as the Dart Sportsman block. Ya a better block would be the Dart with billet caps or the 2503 Bowtie.
On the Sportsman blocks I have seen its a good idea to dust out the mains as they are line bored and the finish looks like a mirror until its line honed and have seen this is issue on every sportsman block.
Here is a pic of Hordogs block as the main bearings did not look good and I dusted out the main line it shows the imperfections of the line bore. Just above the groove cut in the mains you can see the chatter marks.
1 - 17 of 17 Posts
