1 - 16 of 16 Posts
Who sells a good gm pin removal tool for stock wiring harness's plugs. I wouldn't mind buying a kit that will do gm and Delphi connectors. Also looking for crimpers for making new connectors.
Go to a hobbie shop and buy a piece of small brass tubing just slightly larger that the pin you are removing.
Creepy Ass ******
Matco part number MASTERM23 It was a bit pricey, but can do damn near anything. I'm doing my harness as we speak...
DON'T LIFT - JUST SHIFT
Big Eng has crimpers too.
Discussion Starter #7
Does Snap On make a kit like matco? There isnt a matco truck around here that I have seen.
Discussion Starter #9
I really only need one for GM harness's, have any idea what snap on calls it?
Cut me in or cut it out!
I have a old set of Snap-On pin removers, a TT600 set. The round pin tool separately is: TT-600-4. I also have a single round pin tool made by K.M. U.S.A. J-28742.
On the roller...
kd tools, lisle tool, round coin shape,looks like a spark gapper with 4-5 fingers... oreilys auto parts has them in there tool catalog
Matco sells those in a kit of 3 as well...
be careful the late model pin connectors the micro 64 pins use a very thin tool, much like a sewing pin and the test pins are smaller than the regular ones. As a GM tech we have the correct tools here at the shop. I have the MAC tools crimper it works better than snap on, havent tried the matco one
Ebay should have them. You will prob want the green and yellow ones
Tim
Discussion Starter #16
I ran into a snap on truck today and bought the pin kit from them. Its not as big of kit as the matco but I havent seen a matco truck around. Thanks for the help everyone.
1 - 16 of 16 Posts
