Easy to spray? Goods, bads, uglies???
Geerbangr · Registered Joined Oct 27, 2013 · 28,545 Posts Discussion Starter • #1 • Jul 3, 2019 Easy to spray? Goods, bads, uglies???
biga632 · Registered Joined Jun 29, 2010 · 7,175 Posts #2 • Jul 3, 2019 doesn't look like a GM code...what year is it from?
Geerbangr · Registered Joined Oct 27, 2013 · 28,545 Posts Discussion Starter • #3 • Jul 3, 2019 I thought it was the code for 2018 Summit white
Dusterdude · Registered Joined Aug 27, 2016 · 795 Posts #4 • Jul 3, 2019 Any gm relatively new will have a wa..... code or we..... code,may even have a bc/cc number also Sent from my LG-US601 using Tapatalk
biga632 · Registered Joined Jun 29, 2010 · 7,175 Posts #5 • Jul 3, 2019 solid whites no problem...I'd blow 1 coat white sealer and 2 coats base then clear unless you want single stage but would still seal white
