1 - 8 of 8 Posts
I have a gm air pump off of a 98 camaro z28 i want to use as a vacumme pump it has 3 wires which one's do i hook up it has a red black and a pink one. Thanks
out of work hair dresser
It's not going to do you any good. It will pull all of 3 psi at just above idle. The slightest hint of oil in it will render it useless.
So i wire the red and pink up together and how are you guy's hooking your hoses up. Thanks
1 - 8 of 8 Posts
