1 - 3 of 3 Posts
Is 4L60E worth rebuilding?
I've replace couple reaction carrier and planetary gear set with aftermarket stuff but they still do break like stocker.
Is there a stronger reaction carrier and planetary gear set?
The Sun shell can be replaced w/"beast" shell .
The planetaries can be upgraded to the 4L65E 5 pinion ones.
The aftermarket planets are not so good,so only get the G.M. ones.
Also don't get crazy w/pump press. as this will tend to smash the pump.
Good luck
1 - 3 of 3 Posts
