1 - 2 of 2 Posts
Started a new project, decided that is will be a single turbo combo. It will be a street/strip car, driven/beat on running on 93 octane but raced on C16. My question is, how much can a stock 350, 010 block take? Is a drilled/splayed 2 bolt that much better than a stock 4 bolt? I have both a 2 bolt and a 4 bolt block, so that doesn't matter. I'd prefer not to fill it, being this car will get driven a lot. I plan on doing a blow through setup with a carb from one of the reputable builders (CSU, C&S, etc.). It will be either a 355 or a 383, with a cheap set of aftermarket heads (Patriot, RHS, Pro Topline, Dart Iron Eagle, etc.) and a roller cam, do you think I'll be able to squeeze 1000hp out of it? If so, how big of a turbo do you think I'll need? I was tossing around the idea of small twins, but I think a moderately large single will be more than enough, while being more cost effective at the same time. I've played with lots of N/A and nitrous cars, but never forced induction so this is all new to me. I'm not sure what I'll need/what I won't need regarding wastegates, blow off valves, boost controller, intercooler, etc. I'm also not sure what kind of crank/rods/pistons you need to take the boost, so I'll need some edumacating. Trying to do this somewhat on the cheap, so used parts are fine for me.
Custom Engine Shop
Safely, 900 hp for a stock block, Steel Center caps, Short fill.
Budget
4340 crank
L19 H-beam
2618 Piston
B/W S480 Single
JGS 50mmW/G, JGS 56mm BOV
EV Bonnet and CSU or C&S
MSD 7531
1 - 2 of 2 Posts
