Last Friday the wife took our 2003 2500 HD 4x4 (the one with the buttons on the dash to make the shifts from 2WD 4WDH 4WDL ) and the message came across the dash "service 4WD" Well I crawled under it and checked everything out and while it all looks fine and all the wires are still hooked up where they are supposed to be now it wont shift into 4WDL at all dont even make a noise like its trying to shift. And the message is still on the dash. No I have not cleared the fault indicator or reset the system by un hooking the battery so its obvious I still have a issue someplace.
I do need to add a bit of fluid to the transfer case and the book says to use Auto Trak II fluid is that my only option or is there something else I can use?
Another Issue I have with the Transmission is the Trailer Tow mode isnt working any more either ? I can press it all I want but it makes no difference even the little trailer symbol guit coming on in the dash so I am starting to think I may have a bunch of things going on inside there ?
Any ideas on what to try next to cure these issues ?
THANKS in advance for any help.
