1 - 7 of 7 Posts
Its a steel valve body. I've tried more rpm. I havn't adjusted the band. Is it too tight or too loose?
Band adjustment just fixed this very problem on my car this week. I had a brain fart and didn't adjust the band for a good while. It was acting like it was low on fluid, needed rpm to get moving in first. It wasn't until it backed up a couple inches on the brake that it hit me. Band adjustment to 3.5 turns fixed it, no issues last time out. If it just started I'd start with the band adjustment if you haven't done one in a while. If it's always done it since built, it's usually another problem, in my limited experience.
1 - 7 of 7 Posts
