1 - 7 of 7 Posts
have a joels on joy glide in my car 1.80 straight cut set in it. i bought used so i dont know exact details on brand used and such. behind a turbo sbf. was shaking the car down and making lic passes today and had a little tire shake on 1 pass and i lifted a little and it stopped,got back into it and finished the run. next pass i smoked the tires then after that i went 1.49 to the 60' and about 250 or so feet out it died. rear and u joints ok. car barely moves on its own and i can hear something in the trans broke. whats the consensus before i pull it? wont be doing it till this week sometime most likely. just tryin to get an idea what it might be
thanks
what else do you want to know? or do you mean more specifics bout the guts of it?
Should be pretty obvious....Converter , pump , input shaft....
Check your clearance between the flexplate and converter mounting pads as you are removing the trans......
ok managed to get the trans out a little bit ago
obviously i cant fully inspect the converter but it "looks" ok, input also appears to be ok. easiest way to check the pump?
also before i removed it when i had it running the noise sounded similar to a broken rod flailing around. car had no fwd/rev movement cept when rev'ed in nuetral it tried to inch foward in the garage but that was it
Discussion Starter · #7 ·
have the pan off now and there is def something good n broke in there. tomorrow or monday ill prolly tear it all the way down or just let someone do it
1 - 7 of 7 Posts
