1 - 2 of 2 Posts
We fired the car up today with a glide we put in it, I can hear a howling noise coming from the tranny it seams like. You can hear it from inside the car better than the out side. Could the pump be making this noise? The tranny is used.
Could be the planetary if its a straight cut set or could be the pressure regulator if the booster doesn't get fed until put into gear. Does the noise go away when you put it in gear? Does it get worse in reverse? Either way its no big deal.
Hutch
1 - 2 of 2 Posts
