1 - 9 of 9 Posts
What are you guys running for starting line ratios and rear gears?
I just built a 12 degree 632, I would also like to spray it with about 400 to 500,
I currently have an Abruzzi power glide with 1.80 first gear. I have 2 sets of rear gears 3.70 & 4.30.
Car weighs 3100. 14 wide tire.
Bump for some answers
are wheelie bars allowed in that class,if those are the the gears you have and want to run id say the 3.70s and still will prob have to manage power off the line
What are your thoughts on changing the to 1.65 or 1.58 gear sets? I would also like to run a few motor only events.
I’d say keep the 1.80 and use a progressive for the nitrous passes, lots or ways to make it work, the converter will be the key with that much nitrous going to be hard to get best of both worlds
1 - 9 of 9 Posts
