give us more info on the car... weight, hp, max rpm, what coverter and stall and 1/8 or 1/4 mile racing...
we will start there...![]()
how much are you trying to drop down? depending on the converter you may not see much improvement. I would give 4.30's a try but something with your numbers doesn't add up... what times are you turning in this car?
Like I said before I would try the 4.30's but given your MPH with your ET I do not see you gaining much if at all..
