1 - 3 of 3 Posts
i have a 77 nova mild 355 342 gears runs mid 13 for my wife would changing the gear make a difference in picking up some time and if so what gear would be good
It is only going to pickup if your crossing the finish line below optimum rpm. What rpm is peak HP at? and where is it crossing?
You're running mid 13's with a 3.42 gear? Yes, you would most def pick up ET with a gear change. I went from 3.42's to 4.56's and went 14.30's to 13.50's. Use one of the online calculators (Wallace) to determine what gear ratio you want. You're probably running like a 28" tall tire? I say 4.10's if its a street car....
1 - 3 of 3 Posts
