I have them, Swapping them out for a chain. For some reason I just didnt like them. When installed theres slop in the gears, probably tightens when running but I didint like it.
If you want to run a gear drive, run the full cover style with the fixed single idler. I wouldn't use a Pete Jackson style on anything. Otherwise you can either go with a quality chain or a belt setup.
any of the fixed idler ( three gear) type that the backing plate bolts on to the front of block or inside / within the cover itself or "mounting spacer" is as good as you can get...
and then put a cover on top of it.
