1 - 11 of 11 Posts
With the upcoming 1/4 mile Outlaw 10.5 races at Atco, 1320X (MIR) and Englishtown, I am going to purchase a new center section as my car is set up for only 1/8 right now with 3.89 gears.
Twin Turbo Big Block Big Chiefs, Bruno Lenco (2.10 first gear), 3165lbs with driver, 8400 +-rpm shift, 33" tires. 22% trans slip in the 1/8 estimate 13% in the 1/4.
Race calculators can not take place of experience.
Best test pass so far 5.0 @ 157.
How much does a 10.5WX33 grow in height?
Stuck between a 3:40 and 3:50 gear ratio.?
Thank you,
Discussion Starter · #4 ·
1) On the 5.0 , 157mph test pass RPM was 7259 from Racpac.
Tire Height: 34.5
Trans Ratio: 1:1
Gear Ratio: 3.89
Conv slip %: 22% Solved for
MPH: 157 actual
RPM: 7259 actual
2) Calculated at 210 mph with only 15% slippage RPM would be too high.
Tire Height: 34.5
Trans Ratio: 1:1
Gear Ratio: 3.89
Conv slip %: 15% estimated
MPH:210
RPM: 9153 Solved for
3) With 3.40 and a very wishful 220mph.
Tire Height: 34.5
Trans Ratio: 1:1
Gear Ratio: 3.40
MPH: 220
RPM: 8381
Seems most guys who run a powerglide with a 1.86 or 1.90 first gear use a 3.50 rear gear. Bruno/Lenco has 2.10 first gear.
Is it normal to have this much slippage?
Not really a lot of difference between 3.40 and 3.50 just wondering?
Thank you
If Daniel is driving just leave the 3.89's in it, because he'll lift before the finish line. Ha Ha. Just messing with him.
I run a 3.60 gear in my small block 10.5 car,at 203 it went through the traps at 8200
I would bring that converter in. Of course if thats not an option I would error on the side of cuation and go with a 3.40. As you take ratio out the converter slip will go up.
Discussion Starter · #11 ·
Ash:
Running M/T's, their tech department said the tires grow a maxium of 1.5 inches at 150 mph for a total height of 34.5". Ran our first 1/4 mile pass this weekend 7.6 and ran out of gear at 1000' with the 3.89's, data logger showed 14% conv slippage.
1 - 11 of 11 Posts
