1 - 3 of 3 Posts
I am redoing a bent 9" housing from an 80 malibu. We're adding a rear girdle, adjustable LCA brackets, new housing ends, upper adjustble LCA brackets, and all moly, rod end style control arms. On my own "traditional" 4 link, I run -2 pinion angle. What do you guys typically run on your stock style suspensions? 800hp procharged car with a glide. Currently 60's around mid to low 1.30's. Thanks guys.
Similar power (little less), -2.5 to -1.5 with heims on all link bars 60 footed the same. High 1.2X's (with too tight converter). I tried more angle at first, but the u-joints were too far out of phase and it would vibrate like an SOB around the 330' mark.
I have 3 on mine, but am running 1.teen 60' times on a drag radial. It will depend on how hard you will be hitting it and how much separation you are getting.
1 - 3 of 3 Posts
