1 - 2 of 2 Posts
i plan on ordering a TRZ anti roll bar as soon as i find a dealer to go through. i came to the understanding that there is 2 different style bars? can anyone shed some light on the 2?
next, are these chassis braces that TNT makes overkill?
http://www.tntraceshop.com/1978-1988_G-body_180100-180200-180101-180201.html
i have been running the bar that goes from the lower frame side to upper frame side. but since ill be back there putting in a antiroll bar, i figure why not...
if i should get those chassis braces, who do i order them through? i cant find a number that works for TNT?
Stock Suspension FTW!
You can buy direct from us because we give a Yellowbullet discount. One anti-roll is our standard bar that's 1 1/4 and works in most applications. The other larger bar is 1 5/8 and is used in heavy high powered drag radial applications. We have used the 1 1/4 bar since 1990 and when properly installed we don't see any issues.
Anything you can do to support any suspension mounting point is never a bad idea or overkill.
1 - 2 of 2 Posts
