1 - 20 of 37 Posts
For those of you that have done your own garage floor what is a good durable coating? I'm looking to do a solid color not the flakes but it needs to stand up to engine R n R,spills etc. and look good,thanks
anything that is SOLVENT epoxy or solvent concrete stain. both are hot tire and fluid resistant. prefer PPG products
On the roller...
Polish is best. If you can't do that, go with this stuff... I've had great results and used it on more than just concrete. http://www.epoxy-coat.com/
My buddy and myself have both used the above on our garages. I used the anti-skid in the top coat and he did not. I was upset when mine was all done because it was no where near as glossy as his. But that shit is like glass when something is spilled on it without the anti-skid . He re-top coated with the anti-skid after almost falling on his ass a could times.
That would be my concern if it is slick or not. Use to work on my car at a shop that was coated and it was slick no matter what. I have also seen a few that don't like hot tires or a jack being used on top of it.
ho tire roll up is a big issue. shark grip additive for sure. go to ppg.com and check out the procedure for proper prep
i used u coat it in my new shop and its holding up great
On the roller...
I don't anti-skid mine. I just walk with short steps like I'm out on the ice. :D
H & C polish?
No...this is polished. And no, nothing rivals the performance of this type of floor. Because there is nothing there to fail.
Discussion Starter #15
How did you get the spot look, I just have good old concrete,looking for a semi gloss with a non skid.
Lots of Grinding. That is just the aggregate showing.
Sherwin Williams Tile Clad Epoxy. Did mine in light grey. Super durable and been on there for 6 years so far. Wife parks hot tires onvit everyday and no issues. The key is surface prep. You need to etch it with muratic acid. I did 50% mixture with water. Etched it twice. You can drag anything across it and it will not flake.
1 - 20 of 37 Posts
