This may be a dumb question but is it ok to run gaplesss rings with nitrous?? small shot only 125.
Thanks,
Bryan
Thanks,
Bryan
I've run a 300 shot on a set of ZGS rings before.
Gap always matters due to expansion. This goes for N/A, boosted, or N2O as well as the fuel type used.i know you say its okay, but does it matter how much the ring ends are gapped, etc? for those who have done this, what were your end gaps set at or did you not gap the ends at all?
I don't think it was in the gas porting at all. I feel it was in the actual ring stack. Using the same size blower, same rings with same gaps, a different ring stack rendered better results.Billy man-was the gas ported pistions the cause-
if so what kind of issues did u have if u dont mind me asking
Nick--
