i have stock suspension malibu do any one think 12 inch rims will max notch no minnie tubs
There is no sense in doing a max notch without doing a mini tub. Your wheel/tire will hit the stock wheel tub before it hits the frame if you don't.
will a 295 on a 10" wheel fit with a half notch and stock tubs??
sorry to hi jack
I have 295s on a 10" with a 3/4 notch. Still have to roll the lips, but they do fit.will a 295 on a 10" wheel fit with a half notch and stock tubs??
sorry to hi jack
Yes, that's what I did. Also when they were skinned and not welded back up, I took a big ratchet strap and moved them in more, then just ran a bar across the frame rails to keep them thereyou can only run a 12 rim if you skin the frame rail, and take out the stock tub!
What b/s on your rims?295/10" fit mine with a notch to the seam
X2What b/s on your rims?
What kind of back space,and is the rearend stock length?Yes, that's what I did. Also when they were skinned and not welded back up, I took a big ratchet strap and moved them in more, then just ran a bar across the frame rails to keep them there
well they're 3-7/8" and the rear is narrowed to 49", so with a stock width of 52" it should be a 5-3/8"What b/s on your rims?
