1 - 15 of 15 Posts
What length rearend stock suspention aerospace brakes 10" wheel? And back space on the wheels any info would be appreciated Thanks.
YOU CAN GET AWAY WITH 10'S WITH A 4.5" BACK SPACKING. YOU MAY HAVE TO MASSAGE THE FRAME A LITTLE!
I have been through most of the threads on both boards. Was going to order a M9 fab housing but wanted to be sure of the width. and the back space of the wheels Thanks.
believe the stock width of a g-body rear is 52 1/2 backing plate to plate... for a 10" rim with 4.5 b/c,,,, a frame notch will be needed and roll the fender lip..
i've gotten 28 x10.5 Hoosiers slick under my malibu with just fender lip rolled tight on a 15x8 rim with 3.5 b/c stock length rear end..
Discussion Starter · #7 ·
Thanks for the help I'm going to notch the frame friday night I've got all the bars in the frame for 25.5 chassis.
Frame is notched, lowered 1", the rear is shortened 1" each side, had to cut half the lip off. These are 18x10-4.5 BS. 305/45/18 nitto drag radials. With Wilwood disc.
Just pulled my paperwork from my M9 order. 51 13/16 housing end to end. 56 13/16 axle flangeto axle flange.Frame notch,minitub, 15x10 5 b.s.
J&E POWER!!
i got the moser m9 also, i think i have 3/8 shorter then stock length. if you call moser they start with whatever the stock length is, they know already. i have a 10" with 5.5 bs with a 295 and have alotta room. frame is notched, not sure how much.
I have a 65 chevelle 12 bolt. 53-55 inches sounds right. depends on your b.s
X275!
I have a stock width rear end in my car, 15x10 wheels, 6" backspacing, frame notched all the way to the inner and a 315 MT radial and its a tight squeeze everywhere with the car at the ride height that I want (looow)
1 - 15 of 15 Posts
