Does anyone know of a manufacturer that makes a 400th crossmember that uses stock 350th locations? The jegster crossmember does not work with a non overdrive frame.Thanks
There is a bracket that G force offers to use a TH400 in a G body. If you wanna go light weight ICEMAN from maliburacing.com and he is on Ebay makes them
iceman is the way to go. i have an old iceman, looks like the gforce once with square tube and its a heavy piece. but it works for a 200 or 400 with an extension piece.
you can simply cut off the factory tab and place it on the back side of crossmember and re weld it on,been like this on my car for 4 years 540 bbc th 400
