1 - 2 of 2 Posts
Im updating my car to25.5 specs and the main hoop bar #10 sets back in the car behind the pillar , after installing the outer funnycar bar 40a my helmet will fit between those 2 bars . what is the proper way to fix the issue . can i run another vert bar in between these 2 and if so can i use 1 1/4 .058 or should it be run horizontal as are #49 and 50 bars . thanks chuck
Usually, you'd run tubing horizontal all the way around, on the same plain, keep your helmet in. If you add another vertical bar, it will probably look kind of funny. I think spec only calls for 3/4" x .049 for the bars that contain the helmet, but you could use anything bigger than that if youd like.
Good luck!
Kyle
1 - 2 of 2 Posts
