1 - 8 of 8 Posts
how does everyone set the fuel system up on there motor and nitrous side . i have small block chevy on nitrous but cant seem to get where i can run nitrous because the motor is either lean or rich .1st time to track motor went lean n/a 2nd time motor went rich between times to track replaced mallory comp 250 with magnafuel 500 then fuel gauge went crazy and could not adjust fuel pressure for carb below 9 1/2 pounds. does everyone run a return from the regulator or from the pump and dead head at regulator? thanks
Many years ago I was at Edelbrock. We used to go and test at the strip dirring the week when noone was there. Once I tested the affect of fuel pressure. After each run I reduced the fuel pressure by one pound. This was a SB Chevy with a two carb tunnelram setup.I started with 6 to 7 lbs, andd after 5 runs, the gauge read ZERO, but the car ran EXACTLY the same every run, five times in a roe. I can not explain it, but I never forgot it either. Fuel pressure is not very important. . On customers cars I have worked with, I tell them to set it at 6 to 7 lbs and forget it. I get phone calls where people go on and on about the problems they have with fuel pressure, I feel; soorry for them, they should be looking at something else.
JOE SHERMAN RACING ENGINES
I also run a MF 500 pump and could not get the pressure to regulate down. I changed some stuff around and put a 2 port MF for the carb and I use the holley12-803's for each system and it works perfect. They are dead headed and I use the return that is designed to go from the pump back into the tank and thats it!
Works great for me and several others. good luck
"Darkness"
How much fuel volume did you have at zero psi?
1 - 8 of 8 Posts
