1 - 5 of 5 Posts
will this work i have a 4703 efi magnafuel 750 10 line fed 10 return aeromotive 13202 reg this was a blow thr set up im running nitrous for the rest of the year so i have the 10 feed going two a log with carb reg and nitrous reg at the end of log i have the 13202 reg set at 25 psi this should work right?
thanks Hutch I thought it would work i flowed it today wow you were right car running open flow guage and carb pressure doesn't move from 7 psi
1 - 5 of 5 Posts
