I'm using a NOS Launcher progressive controller with Zex Solenoids and when testing it, I found out that when the Nitrous Solenoid is pulsing (on the ramp-in) the Fuel one just opens and stays open until the activation switch is released. If I disconnect one of the wires going to the Nitrous Solenoid, the fuel one will pulse then? WTF? I am sure that they are supposed to pulse together, otherwise the A/F mixture will be pig rich on the ramp-in, right?
I have both Solenoids wired to a common ground which is connected to the progressive controller and the other wire for each is connected to a common 12V supply.
I've checked the wiring diagrams and everything is as per instructions and the controller seems to be working, so I'm thinking that it must simply be that the Zex Solenoids are simply not compatible with the NOS controller - maybe the Nitrous Solenoid is acting as a capacitor and feeding back enough voltage to the Fuel one to hold it open??? Could it be that this is why Zex doesn't make a progressive controller??
Anyone have this sort of issue before? I've already ordered new Edelbrock Solenoids. The only reason I used the Zex ones is because I had them already.
