1 - 3 of 3 Posts
Ok I have Aeromotive #13202 it says 2-20 psi.But the rule of thumb is 1 psi. of fuel for 1 psi. of boost. I am going to run 24-28 psi. So my question is will this thing be enough or do i need something else and if i do what would the turbo guys recommend?
2-20 is the base pressure setting, it will rise 1:1 or slightly above when going into boost! We usually set base pressure at 5-7psi. This one is for carb setup, EFI uses a different regulator.
1 - 3 of 3 Posts
