1 - 8 of 8 Posts
I just put together a 565 bbc that has 11.5:1 it is going to be street/strip can i do a mix ratio of pump gas and race fuel what do you recommend? Single carb ,no NOS
For the street, 93 octane will be fine. Use Shell if you can.
For the strip, you'll need a little more octane to be safe. Leaded race gas and pump gas don't mix very well. If you can find ethanol free pump gas, it will mix better with 110.
You can always use Renegade 110 at the track, drain out what you didn't use, and put 93 back in for the street.
Boss
If you are just looking for a little security when racing at the track renegade pro hot rod 102 would be sufficient. It's unleaded and non oxygenated. When street driving, quality 93 octane would be sufficient.
1 - 8 of 8 Posts
