1 - 6 of 6 Posts
598ci BBC twin 91mms on alcohol. What fuel pump to use to feed this setup. Also belt driven vs cam driven?
Waterman- Big Bertha- belt driven
Sounds like youre going to need a pump in the high 'teen GPM minimum.... with a bigblock and 91's...
Im runing a 12 gpm waterman, and no way will it be enough for your animal... (Im only a sbc & single)...
If you have the room, run the cam drive as it is foolproof and nothing to wear or fail... Dont get me wrong belt drive is fine, but cam is just that much better if you have the room.
Look into a little bertha from waterman as the quality is second to none, and all the big guns with your set up run them around the 18-22 gmp range...as you cant have too muh pump.
Pete.
from across the pond...
x2 on the 20gpm little Bertha belt driven or reverse cam driven.
Yeah, I meant "Little Bertha" not Big Bertha.
1 - 6 of 6 Posts
