I am planning to upgrade from my Holley Black pump (currently dead headed) to a Magnafuel Quickstar 300, or Aeromotive A2000. I see they both have an external bypass. Magnafuel shows the return off the pump bypass going back to the cell, and the feed going to a regulator.
Question is, when using a pump of this style (with external bypass on pump), can I use my Holley 1/2" big port regulator, or do I need to get a return regulator?
Looks like I could use the same regulator and run the bypass to the cell right from the pump. Does this sound correct? What is the proper way to plumb a pump like this?
