1 - 13 of 13 Posts
Im looking for ideas for a electric fuel pump that will run my little 355 and a nos fogger spraying about 300 hp. I was going to do the front mounted setup but I am going to try running both systems with the same pump.
Thanks Greg
Aeromotive A2000
I've had great luck thus far.
Not a fogger but a plate with 275hp
X2 I run a A2000 with a 406 and a two stage plate on my Mustang. Currently set at 200 on first stage 100 on second.
workin it
Bigger is always better. I use the A2000 as well, two kits and motor no prob....
Just make sure your fuel system is capable of handling future plans. Most lickely you will always add more power to it. Put a big pump and plumbing the first time and be done with it.
Also I didnt say but I do street driving with the car and how do the big pumps hold up to alot of street time.
Greg
My A2000 is about 4 years old & has seen its fair share of street miles. Probably not over 1500 or so per year & never a problem.
The one & only problem I had was when I hooked up the nitrous system.... Wasnt a pump problem though, the Holley reg I was using on the nitrous side would go absolutly crazy as soon as the pump kit was activated. Switched to an Areomotive 13205 reg & all was fine. Never a problem since. (I know most people have great luck with the Holley regs, just didnt work for me...:confused:)
x2 i had the same problem with the holley it lol as u said went beserk.... biggger is better
1 - 13 of 13 Posts
