im looking at picking a electric pump for my alcohol carb, i have no room for a belt drive, im looking at the ProStar 500, it says it has a internal bypass,how is that different then a return
would like to run a belt drive but i dont have room, even my water pump is like 1/4 inch from radiatorYou need a mechanical bypass, electric pump by itself will not get you low pressure
at idle and hi pressure at WOT. C&S Specialties has what you need. Been doing that
for 20 some years on a lot of alcohol carbs.
Dwight
I can't see how that would work correctly? Only using the bypass and no regulator?The MagnaFuel 500 Pro Star has a bypass built in. All you need is a line back to the tank from that.
I have a Quickstar 300 which operates the same as the 500. I return to the tank after the pump and run a regulator between the bowls at the carb. I run a 10AN line to the regulator and an 8AN between the bowls. Fuel pressure to the regulator on my junk isI can't see how that would work correctly? Only using the bypass and no regulator?
got a link? think i found not but not sureYou need a mechanical bypass, electric pump by itself will not get you low pressure
Dwight
This. I run a A2000, set my high pressure at the pump with built in return and set my low side on the reg for carb.You still have to run a regulator. I run an aeromotive A2000, and it's the same style pump as the one mentioned above. My return line is about 3 feet long. And now, with the right regulator my fuel pressure is 6.5 from idle to 7500 rpm.
any issue with milking of oilThis. I run a A2000, set my high pressure at the pump with built in return and set my low side on the reg for carb.
Nopeany issue with milking of oil
is this it
http://www.speedwaymotors.com/C-S-Me...-Log,9035.html
393w, not sure on hp, low 10ish high 9ish sec motor, 100% bracket race drag carThat's itHTML:is this it http://www.speedwaymotors.com/C-S-Me...-Log,9035.html
You never did say how much motor(HP,CID), and what you use it for( street, drag,
circle track) ??
Run my pump at 28, and carv 7.5 running no issues. I had a good builder put a carb and reg together for me, if you keep the idle circuit lean, make sure it isnt running off the boosters, and make sure you got heat in the engine before running shouldn't have any issues.i keep reading how on alcohol carbs if the fuel pressure is 7-10 psi at idle it milks the oil
