1 - 8 of 8 Posts
On the roller...
How much pressure should I have in the line with a 255lph in-tank pump and 40 lb. injectors?
Well, unless you need more pressure to increase your injector output, OE Ford is 39.5psi with vacuum off of the regulator. That's what most tunes are based around as far as injector calibration goes... Of course this can all be changed, but should be done correctly.
On the roller...
1 - 8 of 8 Posts
