1 - 1 of 1 Posts
Deciding on a mounting location for the fuel pressure regulator and I want to ask does it matter how far the regulator is from the rails?
Also the intruction for the regulator suggests a "Y" block out of the rails to the regulator. Is that neccessary? I was planning on feeding the front driver side rail, running a line to connect the two rails in the back of the intake and having the front passenger side rail go into the regulator.
Thanks.
1 - 1 of 1 Posts
