1 - 6 of 6 Posts
My original fuel line path brought it up the passenger frame beneath the hvac box and very close to the header where it Y'd off into both the injector and nitrous fuel systems (see attached). I'm considering bringing the line along the frame to the k-member and on into the path beneath where the original battery sat behind the passenger headlight and on to the regulators nearby. Where do you have yours routed?
my main feed goes on the driver side up to the back of the rail, through the rail into a magnafuel regulator out to the nitrous and returned similarly to yours just i brought it up ontop of the shock tower
If you cut the sub frame where it meets the floor and a a hole in the frame you can bring it up infront or behind the rail and keep it away from the headers and flywheel. also we use the dei /thermocool insulator stuff for heat.
1 - 6 of 6 Posts
