1 - 4 of 4 Posts
I have a front mounted 5 gallon fuel cell. I run alcohol. The over flow/vent has a built in roll over. I run a small filter on as a vent. After a burn out and I hit the brakes it can splash some fuel out.
Can I use a small aluminum catch can with a filter to run the ovel flow too?
Can you just raise the height of the vent?
Raising the vent might work. If that's not feasible, then how about adding another 'bend' to it to help fight the slosh?
1 - 4 of 4 Posts
