DRAGON racing fuels / TARRAGON 118
anybody use it before ,or heard of it ????????????
SURE WOULD LIKE TO LEARN MORE :smt100If I am not wrong, Johnny Mac was running there fuel in his NMRA SSO car. Not sure which grade but he was running hard. Sure he will step in and give some feedback.
up!!!!What's wrong with the fuel you are running?
Thats one thing that can phuck your tune up ....
hey frank .. can't get the fuel I run around here ,and the shops are pushing this fuel !! i use compition fuel now !What's wrong with the fuel you are running?
thanks i use comp fuel now so you think i will be fine with this stuff ??Former employees of Torco. Same formulation I'm told. I have sold it to several customers who previously used Torco and Competition Fuels. Seems to be identical, no difference in performance. Hope that helps
I would think you should be fine. Look for Mike Crowley (spl) at the Tomato Nationals. I think he will be running in the 275 class. Also Richard Roberts in 5.50 They are two of the guys that have used it. Good Luck out there!thanks i use comp fuel now so you think i will be fine with this stuff ??
Certianly a good idea to check. I'll see if I can get any specs.I would make sure the specific gravity was the same as the fuel you were using.
Here is the Comp Fuels for Comparison Daveon the sheet i got off there site
sg -720
motor O 113
research O 120+
r+m/2 118
o2 no
color pink
close to comp fuel
thanks frank got 5 hits on new motor and she is tight !!!Ten four Dave don't want to see you burn your stuff up that's all, that's Not a dig on the new fuel I know nothing about it.
