1 - 5 of 5 Posts
What are you using for fuel line? 5/8" steel or aluminum tubing? Or is that too dangerous?
Banned
What's the application ?
have aluminum down the frame rail and areoquip twistlock for the rest nhra legal for fuel so can use more then 12in
mines braided from tank to filter, filter to pump then aluminum to front of car down frame rail to the regulator than braided to the carb.passes tech fine!
I have absolutely no aluminum line on my street/strip car. I don't trust it especially for EFI higher pressure applications. I use either stainless tubing or braided. It's safer than aluminum especially if you get in a bad wreck.
1 - 5 of 5 Posts
