1 - 7 of 7 Posts
I currently use push lock because I hate messing with SS. I recently saw that some companies have a nylon braided hose, just like SS but nylon. How does these compare in durability for a street driven car?
There are quite a few different weaveloc hoses, some are very expensive and most are very light. I use the earls prolite hose with crimped ends and with a typical drysump car i'll save 40#'s of weight.
Any of the leading mfgrs' woven hoses are approved by nhra and the braid is a combination of nomex and kevlar and is very durable. I brought in a piece of the professional products" braid hose and it has an inner braid of stainless wire imbedded into the rubber.
So i guess that the short answer to your question is that it will hold up just fine in a street car, i would just keep it out of direct sunlight as UV light can raise hell with the rubber-like compound inside the weave. btw, the woven hose is much nicer to work with and a great deal more flexible.
Is there one to stay away from?
Or best bang for the buck that is just a durable as the most expensive stuff?
Ive been told not to use the nylon hose on vacuum pump, due to possibly collapsing. There is a steel coil like insert, that can be placed inside of the line to prevent it from collapsing. Keep that in mind.
Yea under stand that.
anyone else input? thats used this stuff?
earls pro lite is the shit just not for a high suction app. Used it on vac pump with no problem. Used stainless braid for oil pump inlets.
Discussion Starter · #7 ·
so oil returns (turbo), fuel line, transmission lines its ok to use on?
1 - 7 of 7 Posts
