I've been using a single pump in the rear this year due to Monty's suggestions last year. I found out for sure you want at least 32 psi at the rear pump, or the G forces will tend to drop the pressure down more than you want at the nitrous regulator, especially on 10psi + solenoid pressure tune ups.
I'm currently using a Aeromotive A2000 dead headed but am getting ready to see what effect a full return style will have. Pressure is now rock steady at the fuel solenoid but I can definitely see the effects of the G forces on the pump pressure. Other cars around here are using the A2000 rear pump dead head setup spraying 500+ going around 8.10's and seem to be working ok for them. But I have no idea what their pressures are doing down track.
